Disables the MAC address lock down timeout feature for the specified port or group of ports or for all ports on the switch.
| all | Specifies all ports. |
| port_list | Specifies one or more ports or slots and ports. |
By default, the MAC address lock down feature is disabled.
If you disable the MAC lock down timer on a port, existing MAC address entries for the port will time out based on the FDB aging period.
The following command disables the MAC address lock down timer set for ports 2:3 and 2:4:
disable mac-lockdown-timeout ports 2:3, 2:4
This command was first available in ExtremeXOS 11.6.
